Exploring the need for a vented loop
So why do we need this vented loop between the toilet and the holding tank, anyway?Here's what I gleaned out of the manuals previously referenced.A. "...to ensure that the contents of the tank do not syphon out through the bowl..." JabscoB. "...to discharge more efficiently and will help to prevent backflow..." RaritanThose were easy, they were in my last post. Now let's dig a little deeper...My particular problem has to do with backflow (water seeping back into the bowl from the discharge hose), so I looked at the Raritan troubleshooting guide."Water rises in bowl at dockside (toilet below waterline)."Two of the probable causes involve the intake side (not my problem) and the third is:"Joker valve leaking."The correction is:"...Clean or replace joker valve. A vented loop is needed in the discharge."Right above that is "Water accumulates in the bowl too fast." and the probable cause is"Joker Valve not closing or opening properly."Corrective action: "Close intake valve and pump dry. Clean or replace joker valve. NOTE: Routing discharge hose above toilet helps joker valve close tighter."And the note is in BOLD in the manual.The only possible explanation I can find for this note is that there is water in the discharge hose that presses on the joker valve to help it close.From the Raritan user's manual:"Pumping several strokes after the bowl has been flushed will help to clear the lines, minimize odor and reduce the possibility of backflow into the bowl."From Jabsco:"After use, keep the Flush Control shut and pump until the bowl is empty. When the bowl is empty, open the Flush Control again, and continue to pump until all waste has either left the boat, or reached the holding tank (allow 7 complete up/down strokes per metre (yard) length of discharge pipeworkThen shut the Flush Control and pump until the bowl is empty. Always leave the bowl empty to minimise odour and spillage."And finally, from Jabsco, referring to the advantages of having a loop in the discharge line even when the toilet is above the holding tank:"This will create a water seal at the Joker Valve that will prevent bad odours from escaping through the toilet."So Jabsco and Raritan agree on these issues.That leads me to 2 more assertions:4. When the hose from the discharge elbow on the toilet to the holding tank runs up-hill, there is normally water in the hose.5. The water in the hose helps seal the Joker Valve, so having a vented loop will increase the pressure, therefore the seal.There, that was fun!Comments?Cheers,Bobs/v X SAIL R 8
