G
Glenn Newcomb
Today I ripped out every piece of hose and the holding tank on my Hunter 33. I plan to replace all of the hose with SeaLand Odor-Safe and I have a new SeaLand holding tank on order as well. I am also replacing the 10 year old head with a Raritan PHII.I have read almost everything I can find about placing vented loops in the lines. I plan to install one in the 3/4" inflow between the head pump and the bowl as suggested in my reading. This should ensure that the pump will prime, while still providing safety against pump failure and siphoning.My question involves the 1 1/2" outflow from the bottom of the tank. I am installing a dual fitting at the bottom of the tank to allow for a run to the pump-out on deck as well as a run to a manual pump to a 1 1/2" thru hull. It is very rare that we would ever need to pump overboard and the 1 1/2" seacock stays closed all of the time. If I need to pump overboard, I would open the seacock, operate the pump (located 18" from the seacock)and re-close the seacock.Do I need a vented loop here? Because of the location of the 1 1/2" outflow fitting on the tank and the route the hose would have to take to get to a vented loop above the water-line, I am adding several 90 degree turns that would not be required to go directly to the pump and then the seacock. My feeling is that as long as the seacock stays closed, I am pretty safe.My old system had a Y-valve to pump from the head directly overboard or to the tank. It also had a vented loop on the 1 1/2" outflow side after the manual pump, but no vented loop on the 3/4" inflow. This was a very complex system with hoses and valves literally jammed under the settee. I want to avoid this complexity in my new system.Am I jeopardizing my boat by not having a vented loop on the 1 1/2" line?
