How it works
A vented loop has a one-way valve in it (at least it's supposed to...if there's only a nipple at the top that has a hole in it, the air valve is missing) that allows air into the line to break a siphon, but shouldn't let air--or anything else--out. If a vented loop were installed between the thru-hull and the pump, it would interfere with the pump's ability to prime...the pump would just pull in air through the air valve. But a vented loop can't stop water or waste from being pushed over it, so it has to go between the pump and the bowl because the pump is no longer pulling water, but pushing it out.On almost all manual toilets, there's a short piece of 3/4" hose that connects the pump to the back of the bowl...that hose has to be removed and replaced with two pieces of hose long enough mount a vented loop above the toilet that's at least 8-12" above the waterline at any angle of heel (or hell, as the case may be<g>). It's also necessary to install a vented loop in any hose connected to a below-waterline through-hull--direct toilet discharge and/or tank dump through hull...same "rules" apply--at least 8-12" above the waterline at any angle of heel.A vented loop in the line does NOT mean that the thru-hull can be left open while underway. CG and ABYC safety standards call for keeping all seacocks closed except when actually in use and therefore readily accessible. However, because today's boat buyer considers decor more important than safety, boat builders ignore the standard and put them in locations that makes it all but impossible to open and close them as needed. The solution: shut-off valves inline in the head intake hose and any head discharge hose that goes directly overboard that are in readily accessible locations. Keep those valves closed except when the toilet is actually in use. Don't even THINK of relying on the dry/flush valve in the toilet...not only do those valves, especially in Jabsco toilets, have a VERY high failure rate, but people are all too prone to leave 'em in the wrong position.
