E
Ed Schenck
Peggy, yesterday I removed a teak panel behind which is the vented-loop. The vent was capped since it is directly under a shelf. This is original on an H37C for you other Cherubini owners.There may be room for an elbow fitting between the loop and the shelf. Question: does the vent hose have to remain higher than the loop? Could the vent hose drop down to go through the same hole as the waste line which is lower than the loop? What is the penalty for not having the loop vented(for the past 21 years!)?
