Vented loop location
744
Hunter 25_73-83 Burlington NJ
Peggie, thanks for your reply that somehow went to the archives before I got to read it! I am installing this little holding tank under the after end of the vee berth. The manual pump-out pump goes immediately aft of it, pretty much on the centreline and below the level of the top of the tank. I will have to run the deck pump-out fitting and the tank vent to either side, as vertically as possible towards the deck but going almost straight out of the tank athwartships till the hoses are away from the sides of the vee berth. These locations are constrained by the available space. I need to know where to located the vented loop(s). I would like to put them high up on the vee-berth bulkhead, above the shelf along the hull (there will be lockers enclosing them) to either side. I am also intending to plumb as much of this system as possible with PVC and not porous hose. I have often wondered why 3/4" vented loops are made at all, unless they are not for sanitation systems. Maybe they are for the vent-- hence my question about a vented loop going in the vent line. Also-- does it make any sense to have a vent line going from the vent on the vented loop itself up to the deck-- i.e., to remove vapours or whatever? Or can these be safely and practically left to vent into the accommodation of the boat? Thanks for your help. JC 2 cherubiniyachts@aol.com
Dennis Thomas
Why vented loops?
Peggie, jump in here with corrections but this is the way I understand the problem. First, understand why a loop is need – vented or not. It is to prevent reversal of direction of flow when the boat is heeled such that what was once up-hill is now down-hill. You don’t need a loop for the line from the tank to the deck pump-out. It’s never going to be open to any potential back flow. If you have a Y valve to pump overboard you might need a loop between you tank and the seacock if you were going to leave it open all the time. You should do that, so you shouldn’t need one there either. You should have a loop in the flush water intake line between the seacock and the head pump. (Here’s a use for the ¾” vented loop) This is to prevent flooding when the pump valves leak or when on certain directions of heel. You also need a loop in the waste hose from the head to the holding tank. Again, you don’t want that coming back to the head when your heeled over or if the tank is up-hill from the head. The purpose of a vent in a loop is to “break” the siphon that could form to cause a reverse in the normal direction of flow in the pipe when the pipe is completely full; sea water into your holding tank or holding tank into your head, etc. If it’s working properly the one-way valve in the vented loop only allows air to inter the loop. No fumes escape out from the loop vent. Some vented loops don’t have a one-way valve, just a small hole to let air in (and out). These need a vent line to take the fumes outside the boat. s/v Anodyne
Vented Loop on Inlet?
Good explanation, Dennis, but I think "You should have a loop in the flush water intake line between the seacock and the head pump" is wrong. The vented loop here should go between the head pump and the bowl. Stu
Dec 2, 1997
9,005
- - LIttle Rock
No vented loop in tank vent line
Vented loops are only needed in lines that carry liquid...something a tank vent line should never do. 3/4" vented loops go in the head intake...NOT between the thru-hull and pump, but between the pump and the bowl. Putting it between the thru-hull and pump will allow air into the line that prevents the pump from priming. Dennis got it almost right, but missed on a couple of points. A vented loop has two functions: 1. it creates a arch in the line above the waterline, preventing water from a thru-hull below the waterline from finding it's own level via a toilet that's also below the waterline. 2. it creates an air break to prevent a siphon started by flushing the toilet from continuing. It will not, however, reverse the flow of water through a hose. You don't need a VENTED loop in any line from the toilet to the tank...however, in most cases a loop is advisable--to create a "hill" in the line that tank contents can't get over to flow back toward the toilet when you're heeled. And btw...loops, vented or otherwise, should be at least 8-12" above the waterline at any angle of heel. Hard pipe should only be used for long straight runs...every "cemented" union in a run with lots of bends is a potential leak...and MUST be "soft coupled" to anything rigid--tank, toilet, y-valve, thru-hull, etc--by enough hose to cushion shock and allow for flexing without cracking the pipe.
Jan 22, 2003
744
Completely confused on vented loop
Okay, now I am completely confused. Putting a vented loop between the head pump and the bowl sounds totally wrong-- the toilet is already plumbed without one from the manufacturer. As I see it the purpose of the vented loop is to break suction between below-the-waterline seacocks and devices they are intended to serve. In other words, if the head is close enough to the waterline level, there should be a vented loop between its inlet seacock and the head, and one between the head and the outlet seacock. They are vented because otherwise they would do no good to extend up some locker bulkhead above the waterline since, once primed, they would enable full suction and still draw water up and over the loop into the head-- and flood the boat. It is the same principle by which your house's washing machine discharge is not a direct watertight connection but instead just some hose dipped (not all the way down!) into the top of a standpipe. If it were plumbed directly to the sewer, once primed it could allow the sewer to back up into your washer. I am asking this because I want to know how to plumb it once the direct overboard discharge is out of the picture. As I see it the only reason for a loop, vented or otherwise, in the head discharge line is to keep the holding tank from backing up into the head bowl, which a check valve could easily prevent. Stinky or not, that is not going to sink the boat. The vented loop most probably needs to be on the tank's overboard-discharge line-- and my question is whether it should be before or after the manual discharge pump. The tank, the pump, and the head itself are all located with the top of each about level with the waterline. I am beginning to think it doesn't matter where the vented loop goes-- probably downstream from the pump is best. I will use as much PVC as possible to prevent clogs and permeation odours, so I am not worried about pumping effort. Any experts with a better clue? JC 2
Dec 2, 1997
9,005
- - LIttle Rock
I'll try to unconfuse you...
"Putting a vented loop between the head pump and the bowl sounds totally wrong-- the toilet is already plumbed without one from the manufacturer." Only because a vented loop in the intake is only necessary if the toilet (or any part of it) is below the waterline...and not all are, so it would be a waste of money for the mfr to include 'em in all toilets. But if you read the installation instructions, you'll see that they call for installing a vented loop between the pump and the bowl in all below waterline installations. The instructions for the Jabsco manual toilet are here: http://www.jabsco.com/prodInfo/overview/29090_MANUAL_TOILET.PDF See the drawing at the bottom of page 2. You'll also see it illustrated in the installation instructions for the Raritan Compact here: http://www.raritaneng.com/pdf_files/compact_II/L219compactIIv0502.pdf and the Raritan PH II here: http://www.raritaneng.com/pdf_files/ph_II/L04phiiv0102.pdf Every one shows the vented loop between the pump and the bowl. It has to go there because the pump PULLS water from the thru-hull...anything that allows air to be pulled into the line to break a siphon would also interfere with the pump's ability to prime. But the pump PUSHES water to the bowl (and also through the head discharge line)...the air break in a vented loop can't interfere with water being pushed through a line, it'll only push water out the hole in the nipple if the one-way air valve is missing. So even if it still doesn't make sense to you, read and follow the directions when you install the toilet.
