E
Ed Schenck
Well the Cricket now has a vented-loop. And yes, Peggy, between the pump and the bowl.
You can see it over on the "Photo Forum". It would have only taken an hour(not 15 minutes) but it leaked like a sieve at the inlet side of the marelon loop. I had to use several wraps of teflon tape and two clamps to stop it.The original hose came off easily. I had to loosen and then turn the elbow at the top of the bowl to point directly to my right. Besides the leak the time-consuming tasks were removing the panel that covers those loops and hoses and securing the new loop to the bulkhead. Fortunately that is not the hull.Now I can inadvertently leave the lever in "WET" with the thru-hull open and NOT sink the boat.
