vent pipe backing up
8
2 28 Palacios
Hello all
Pumped the tank out and rinsed over and over.. Now when I flush jabsco, after a few seconds, the vent pipe burps and spits out waste water onto deck. Just deodoriser and pee pee.. But What is my problem here?? any feedback appreciated.
Mark:doh:
Dec 2, 1997
9,011
- - LIttle Rock
Your tank is still full
Which means your tank vent is blocked.
A tank vent has two main functions...to to provide an escape for air in the tank displaced by incoming waste, and to provide a source of air to replace tank contents as they're pulled out. When the the vent is blocked, neither one can occur.
So what has happened is, the pumpout could only remove about a gallon before it pulled a vacuum....so when you pumped and rinsed, a gallon at a time is about all you pumped out and then flushed out.
The two most likely places for a vent blockage to occur are the vent thru-hull and the connection to the tank--both that end of the vent line and the vent tank fitting. Clean out both, then pump and rinse and again and I'm pretty sure you're problem will be solved.
To prevent it in the future, backflush the vent every time you pump out and/or wash the boat.
You might also want to check out the link in my signature...it goes to a comprehensive "marine toilets and holding tanks 101" manual that should teach you how to operate and maintain your system to prevent 99% of problems instead of having to figure out how to fix 'em.
Dec 3, 2003
544
None None Rochester, NY
Another thought is to check that your vent hose does not dip below the connection point on the waste tank. If it has a dip in it, water (or whatever) could collect and block the natural flow of air from the tank. When you flush, the sudden pressure change could cause waste to exit the vent. This happened to me, and it was only a matter of supporting the vent hose to the proper angle, and cleaning the hose as Peggie suggested.
