vent mushroom
Nov 2, 2008
10
Hi gyus. May be someone have one of those two mushrooms vents original Vega has aft which you don't use. Would be glad to buy it. I have just crushed one of mine yesterday.
Oct 30, 2019
1,459
Think about one of those nice solar powered vents, which have a ni-cad battery and work even after the sun has set. Very effective and an easy install. I have 2.
For example, West Marine part 6775944.Nicholas H. Walsh P.A.
111 Commercial St.
Portland ME 04101
207/772-2191
Fax 207/774-3940
This email is from a law firm and may contain information
that is privileged or confidential. If you suspect
you were not intended to receive this email,
please delete it and contact us.
Sent: Tuesday, March 23, 2010 8:27 AM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] vent mushroom
Oct 31, 2019
12
Hi Steve,
Is it possible to get the vents in stainless? I have now trodden on both mine and don't really want to replace them with more plastic ones!
On a separate subject, and at the risk of raisiOnng a hoary old topic, I plan on replacing the forestay plate/bow roller this year. Before I go to the expense of getting one made one-off, is there a stronger fitting which I can get off the shelf?
On a separate, separate subject, should I be considering replacing the chainplate U bolts? The existing ones look as if they are the original 1973 fittings. There is no sign of movement between the bolts and the deck.
John Booth
Vagrant1718
