K
Kim Efishoff
Peggy,The accepted way to connect a below the waterline sanitary system is to have vented loops in 1) the toilet intake between the toilet pump and toilet bowl; 2) between the holding tank waste discharge pump and the thru-hull (prevents leakage back through the waste discharge pump and into the holding tank - the holding tank would fill to the waterline); and 3) between the toilet discharge and thru-hull (when an option for discharging the toilet directly overboard is included).However, it seem to me that both the vented loops in cases (2) and (3) above could be eliminated (there are several advantages to eliminatinging vented loops) if the following is done:(1) Connect the toilet discharge directly to the holding tank. It's not as nice as pumping directly overboard when at sea, as one now must deal with the holding tank in all cases. However, the holding tank can still be pumped directly overboard as required and as legally allowed. If one intends to abide by the law, this minor inconvience should not really matter (when at sea, one can pump waste overboard in two steps instead of one, and when in restricted areas, the waste must go in the holding tank anyway).(2) Open the waste discharge thru-hull only when pumping waste directly overboard (as allowed by law) from the holding tank. When not pumping waste overboard from the holding tank, keep the discharge thru-hull closed, thus eliminating the leak back through the waste pump and into the holding tank.Of course, the vented loop at the toilet intake is still required to prevent flooding the toilet bowl (and the boat!). And the holding tank must include a line that allows pumping out at the deck (for restricted waters), which is incorporated into the system by placing a Y valve at the holding tank discharge that splits between the deck pump out line and the overboard discharge line.Connecting the toilet directly to the holding tank, thus eliminating the vented loop at the toilet discharge, means that the volume of waste water pumped into the holding tank with each flush is much less when sailing in restricted waters (the line to the holding tank is much shorter in length, thus less volume of waste water goes into the tank - this could be a waste water volume reduction of as much as 200 to 300%!). Therefore, instead of needing to pumnp out the holding tank every couple of days, you may be able to get a week or more out of it, depending on how you use your facility. If the holding tank is properly vented, and the "good bugs" are added to your waste in the holding tank, this should not cause a problem.Eliminating the vented loop at the holding tank's direct overboard discharge reduces the length of this line, and makes it less likely that waste will remain in the line after the holding tank is pumped dry. With a long (vented) discharge line, the only way to make sure that all the waste has been flushed out of the holding tank discharge line is to first pump the tank dry, then add additional water from the toilet, and then pump the holding tank dry again - right?
