Hey Peggie, thanks for a great forum and you put me on the right track a year ago when I had some issues with the head. I'v now reached the point were I'll take your advice of increasing the vent line, I'm tired of having to clean the 3/4" or whatever is there and need something better.
I have a 2" hose leftover piece from redoing all the "active" plumbing and I wouldnt mind using it for this, its good quality santitation hose. I also checked the plug on there now and it seems to have a converter from the regular 2" to the 3/4" with some kinda plug, I think I can get that off and go straight to the tank but what type of fitting shold be on the outside of the boat ?
The current vent is close to the toe rail and high with a clamshell, would i just get a bigger clamshell or just go thru hull... Do you also have a recommended thruhull for this purpose? Also are there anything special about the connection to the tank?
thanks!
Gaute
thanks!
Gaute
