vega mast support problem.
Hello dear Vega ovners, during this winter i am refreshing my vega 799. I cant find exact info where and how you beef up mast support, because i cant anymore close boat doors. If it would be possible, someone could post some photos or some instructions how to replace it. What material should i use, i heard about stainless steel, aluminium, but then there has been guys just fixing it with plywood. And aperently my vega dont have mast leg, did they even came with those, and is there some internet shops where i could order it.. Hope to get soon some usefull answers.Roland,Vega 799, Helsinki
Feb 13, 2010
528
I can't help you with how to fix it but some others on the list have
repaired theirs. The Prototype for the Vega was a wooden boat. Back
then we did not tighten the rigging very tight. Most boats had a
mast going down to the keel and if you tightened the rig tight and
left it tight it would push the keel down and open the seams. This
more loose rigging was a big part of the reason glass boats were
faster in racing. Vega is glass but the bulkhead and mast suppoert
are wood just as is a wooden boat. Back in the 1960's nobody ever
dreamed of pulling the rigging banjo tight. I keep mine loose and
only tighten them if I am going to race. The difference in pointing
and speed to windward are almost unrecognizable except if you are
racing around the buoys. The Vegas were never intended to have
tight rigging. This doesn't solve your problem but some here who
have fixed the same problem on their boats should come on here with
some advice. Doug
n4lbl
Oct 7, 2008
307
I guess I am about to find out if we permit attachments. If the .pdf
document that I've attached doesn't propagate I'll send it directly. I
hope it helps.
Alan
minke, V2505
Alan, There wasn't a pdf attached to that message but if you could send a copy to me that would be great- the mast support on my vega is going to be reinforced this summer and any suggestions about how to do it would be much appreciated. Carl To: AlbinVega@yahoogroups.comFrom: alan.schulman@...Date: Tue, 11 Feb 2014 17:55:04 -0700Subject: Re: [AlbinVega] vega mast support problem.
hope it helps.
Alan
minke, V2505
Sep 17, 2012
9
Hi Alan,
As that is a document that I may want to see as well, maybe you could post it to the yahoo groups file section:
I think that there is a little additional info in the files regarding the mast support already, but the more the merrier.
Cheer,
Matias
From: AlbinVega@yahoogroups.com [AlbinVega@yahoogroups.com] on behalf of n4lbl [alan.schulman@...]
Sent: Tuesday, February 11, 2014 6:55 PM
hope it helps.
Alan
minke, V2505
Jan 28, 2001
694
Hi Roland, I'm guessing that you have a Series 1 by your hull number. My question for you is are you trying to fix a problem or are you trying to avoid a future problem with the mast support. I have Lyric, hull # 120. The mast support on her is fairly heavy duty compared to other later model Vegas I've been aboard. I've not had any problems with the mast support. I'm not sure when they changed the design. I also do as Doug suggests, keep the wire somewhat loose. Perhaps Steve might want to comment? Walt From: matias-perret@...To: AlbinVega@yahoogroups.comDate: Wed, 12 Feb 2014 01:05:46 +0000Subject: RE: [AlbinVega] vega mast support problem.
Hi Alan,
Cheer,
Matias
hope it helps.
Alan
minke, V2505
Jan 28, 2001
694
Oops. I read the post again and saw the part about the door not closing. Good luck with the fix. Walt To: albinvega@yahoogroups.comFrom: bestvega@...Date: Wed, 12 Feb 2014 01:58:27 +0000Subject: RE: [AlbinVega] vega mast support problem.
Hi Alan,
Cheer,
Matias
hope it helps.
Alan
minke, V2505
Nov 8, 2001
1,818
Hi All
Mast support problems sometime appear when the
standing rigging is set taut, usually for racing purposes. There is a kit
available made from us here in the UK. Email me off group for details (steve@...).
Consists of a stainless support beam with spreader
strip etc.
The Series III Vega dont seem to have this problem
as the support was beefed up considerably during manufacture.
Cheers Steve B
Sent: Wednesday, February 12, 2014 1:58 AM
problem.
comment?
problem.
Hi
Alan,As that is a document that I may want to see as well, maybe you
could post it to the yahoo groups file section:https://groups.yahoo.com/neo/groups/AlbinVega/filesI
support already, but the more the merrier.Cheer,Matias
on behalf of n4lbl [alan.schulman@...]Sent: Tuesday, February
11, 2014 6:55 PMTo: AlbinVega@yahoogroups.comSubject: Re:
.pdfdocument that I've attached doesn't propagate I'll send it directly.
Ihope it helps.Alanminke, V2505On Tue, Feb 11, 2014 at
3:52 PM, koob@... wrote:
Nov 8, 2001
1,818
Hi Roland
I supply a Mast Support System for £110 plus carriage. I ahve attached the fitting instructions so you can see what it entails.
Cheers
Steve Birch Vega "Southern Comfort" V1703
Sent: Tuesday, February 11, 2014 10:52 PM
Subject: [AlbinVega] vega mast support problem.
Roland,
Vega 799, Helsinki
Thank you all for good tips, hopefully this will solve my problem, pdf is just what we were missing here. Does anyone knows whats going on with mast leg? Has it ever been in albin vega?Roland,Albin Vega 799
Apr 2, 2013
283
Hi Steve,   Is this the stainless steel arch at the top of the bulk head? While I am redoing my boat I was going to beef up this mast support system while I have the time to take care of it. Please send me the info on what you have for this. Also I think I would like to go with the hinged mast system as well. I will be lowering my mast by myself and the hinged system sounds like that is what I need to do? Please advise. Thanks,Larry V-2761Sent from Windows MailFrom: steve@...Sent: ‎Wednesday‎, ‎February‎ ‎12‎, ‎2014 ‎1‎:‎07‎ ‎AMTo: AlbinVega@yahoogroups.com
Hi Roland
Cheers
Roland,
Vega 799, Helsinki
Nov 8, 2001
1,818
Hi Larry
Email me off group on  steve@...
Cheers
Steve
Sent: Thursday, February 13, 2014 8:28 AM
problem.
Hi Steve,
Thanks,
Larry
V-2761
Hi RolandI supply a Mast Support System for £110 plus carriage. I
entails.CheersSteve Birch Vega "Southern Comfort"
V1703From: koob@... Sent: Tuesday, February 11, 2014 10:52
PMTo: AlbinVega@yahoogroups.com Subject: [AlbinVega] vega mast support
problem.Hello dear Vega ovners, during this winter i am refreshing my
to get soon some usefull answers. Roland,Vega 799,
Helsinki[Non-text portions of this message have been
removed]
Steve,Would you kindly send me details of the mast hinge system too please.Geoff #################################################
Geoff Blake, G8GNZ JO01fq: Chelmsford, Essex, UKgeoff@... or melecerties@...
Using Linux: Ubuntu 11.04 on Intel or Debian on UltraSparcand Apple OS X 10.8.2 Mountain Lion on my Macbook Pro. Avoiding Micro$oft like the plague.#################################################
