Vega combi propeller unit
Aug 31, 2002
8
Hello
Can anyone point me toward a source of technical info regarding the
Vega's feathering propeller? Is there any guide availble to help in
maintaining it?
Thanks, Craig Walsh
Oct 31, 2019
562
Hi Craig:
I've taken off and maintained this propeller quite often. I have a book
showing
all parts. If you like, I could send you pages of that book. (best as FAX)
Please let me know.
Wilhelm V-257
Oct 31, 2019
562
Hi Craig
I'm sending you the pages showing the prop and rev. mechanism (to your
e-mail address)
I don't know how much you use your prop- but I would check the bushing (
#17). If it
needs to be replaced, you have to take out the shaft (and sleeve).
It looks scary, but it's easy once you've done it. Just open the locking
nut (#62) and then
open the 2 little doors (#85), loosen screws (#75.. there are 2) and
push the shaft back.
Be careful not to loose the key (#27 from prop. equipm), and be careful
to get the clamping
element (there may be 2) (# 63).
Once you have the shaft removed from the boat, open nut (#14) and give
it a good wack
(put some wood between the nut and the hammer), the shaft commes out
very easy from
the prop. DON'T do it the other way, like trying to push the prop off
the shaft!
I advise to replace bush (#17). To do this use a hack-saw blade and cut
a "V" into the
bushing (it's fiberglass). Then use a screw driver and just push the
bushing upwards
and it then should come out very easy. Clean everything good, and push a
new bushing
inside (again using a wooden media between hammer an bush).
I also recommend to check the stuffing box, at the least replace the
seal-rings (2) (#25)
Check the drawings for O-rings, replace them if you see water anywhere.
You can get
everything from Sweden - it's a small expense since you already have the
prop and shaft
outside. I carry a spare stuffing box and have most O-rings and
bushings.. just in case.
Good luck.. and happy sailing
Wilhelm V-257
Oct 31, 2019
562
Craig- your e-mail carrier refuses to accept my e-mail! I don't want to
utilize this yahoogroup for sending you the pages
Wilhelm V-257
strausswalsh wrote:
Oct 30, 2019
77
Wilhelm, would you please-mail the pages to me on the prop also. Thanks, I don't have a fax machine. Dave
V3233
lastgasp @ icehouse.net
