I've just run into a problem I'm having trouble making sense out of.
I normally leave the door to the Vberth latched open. Recently, while sweeping the cabin sole I went to close the door, but it wouldn't close. Upon closer inspection I found that although the top of the door seems fine, the bottom edge of the door protrudes about an inch or so past the door frame.
Now, the boat has been on the hard for several years, so the only possible thing I could come up with is that the entire bulkhead may have shifted. Does this sound possible? What else could cause this? It's a lot more than warpage could cause.
Also, what do I do to remedy the situation? The simple solution is to trim the door so it closes, but that only attacks the symptom, not the cause.
Thanks
Thanks
