Bob - Bristol Finish works great
Bob,I have been using Bristol Finish for about 3 years now and am pretty satisfied with it. It is a two part poly-urethane product instead of varnish, making it longer lasting. You do need to prepare the surface as you would do for varnishing (otherwise it breaks down pretty quick). However, you only need to apply it at most once a year, it only takes four to six coats to get a great finish, and it looks as good as varnish.I must reiterate that surface preparation is the key. A smooth, dust free surface is the trick to a long lasting finish, no matter which product you use.Fair winds,Les Murrays/v Ceilidh'86 C-36 #560
