Varnish for companionway stairs on Cat 320
May 29, 2013
7
Catalina 320 San Francisco
I am trying to refinish the companionway stairs on my Cat 320. I sanded them, requires a bit more sanding but it is getting there.
My question is what kind of material to use for varnishing? Some Googling got me Waterlox but there are different types and I was a bit confused.
Should I use a Waterlox Marine or (considering that is inside) will non-Marine Waterlox do the job as well?
Also for Waterlox Marine, do I both need both sealer and the finish?
And finally anyone knows if I buy Waterlox in California, they don't seem to ship directly here, regulations??
I guess I asked a lot, thanks a lot in advance.
Claygr
Feb 10, 2014
75
Catalina 387 Milwaukee, WI
Try Catalina Direct - they most likely have the same varnish used by Catalina Yachts in stock. I purchased varnish for our C387 and it matches up exactly. Call them if you don't see it on the website.
Jan 4, 2006
7,268
If you want a finish that will last forever, consider covering with light glass cloth and clear epoxy resin. A fair bit of extra work but mine still look like wet varnish after four years .......... and lot's of little grubby sandy feet.
http://forums.sbo.sailboatowners.com/showthread.php?p=993090&highlight=companionway
