Brad Dennis
Replaced my fresh water pump with a 4.5gpm variable pressure pump but original problem continues. Water pressure does not build up to the level it once had with the 2.5 pump, it speeds up and slows down and generally acts like it has air in the system. Water also goes from hot to cold and back while taking a shower. No noticible leaks are discerned anywhere in the system (except high up in the water tank which ends after the ater leaks out to a point below the location of the crack
). I have removed, replaced, and reset the accumulator tank (although one is not really needed now). Have also, removed and replaced the in line filter, no difference in or out, other than the water tasting better with it in due to one's imagination of all the stuff not being filtered
. All clamps are tight, water level (even below the slight crack) is well over 2/3rds full and problem exists in all outlets.Anyway, it is frustrating not being able to locate what acts like an air leak but shows no signs of water leaking out anywhere. Any suggestions would be greatly appreciated.Thanks,Brad
