Vanity Mirror Replacement
Rick D
Jun 14, 2008
7,182
My mirrors lost their silvering over the years. This happened around the edges. I took measurements to a local glass shop and they made up a new set. I told them to use a dime to figure out the corner radius. Anyhow, I just put them in this week after tripping over them in my garage for four months.
The most difficult step is the removal of the old mirrors. I got some thin music wire from my local hardware store and two 1/2 inch PVC pipe studs. I drilled a hole in the pipe studs and threaded the music wire to each one to use as pulling handles.
There are four mirrors, two about a foot square and the others maybe 30 and 24 inches X 12 or so. I used the music wire to slip behind the mirrors and 'sawed' through the adhesive on the back after protecting the fiberglass edges with some tape. This worked well on the two small ones. The larger mirrors proved to be a problem, tho. I could do the edges and some way up, but I kept breaking music wire when i tried to go to the middle of the mirror. There was just too much drag.
I put tape on the mirror and broke one with a hammer and punch. Bad idea. Too many small pieces and shards. Still, I was able to remove the mirror with a combination of a putty knife and the piano wire. For second larger mirror, I tried to heat the front with a torch to make the adhesive softer. In the course, I put a crack in the mirror. I then took a glass cutter and scored the mirror into 4 square inch parts, thinking I could heat the mirror to cracking and it would follow the scores. It didn't. However, I was able to crack the mirror in a controlled way with the torch heat and remove the pieces with the putty knife and piano wire. IMHO, that was the way to go.
Then, I used a single-edge razor blade scraper tool to remove the adhesive residue from the fiberglass. Piece of cake.
For the installation, I used a tube of mirror adhesive. It is formulated so as to not attack the silvering. After putting them in place, I taped the mirrors to assure they stayed in position for the week it takes to cure. After that is done, I will caulk the edges with color-matched caulk (almond) so as to keep moisture and air from the back of the mirrors and prevent having to do this again some day.
Couple of other things: wear eye protection. Gloves are good as are long pants and shirt. I had shorts and t-shirt and no gloves and wound up with some annoying slivers. :redface:
Anyhow, the result is worth the trouble and is a simple process.
7,334
Alden 50 Sarasota, Florida
Nice job and good write-up Rick. Mine are beginning to show their age too and this helps.
Spent my day winterizing...
Mar 12, 2008
557
Jeanneau 49 DS San Pedro, CA
Looks nice; I'll have to stop by and check it out when you finish. Winterizing??? Rick and I are just getting started. This is one of the best times of the year for sailing.
Rick D
Jun 14, 2008
7,182
Way To Move Thread..
...to the 40.5 owner modification section (or other appropriate)?
Nov 8, 2009
537
Hunter 386LE San Fancisco
Re: Way To Move Thread..
Rick D,
Very nice job. When it came to replace my 4 corroded glass mirrors in the head I went with cut to fit mirrored plastic from Taps Plastic, glued to the wall and and trimmed them off with teak to hold them in place.
Rick D
Jun 14, 2008
7,182
Thanks. When I did this two years ago, I simply got annoyed at how they looked. Two years later, still good w/o any signs of deterioration. The latex caulk I put around all the mirrors seems to have done the trick as to keeping moisture off the silvered side of the mirrors. Figured this might help other owners. It seems to happen on all of them.
Jun 9, 2004
963
Hunter 40.5 Bayfield, WI
Rick-
I am so happy to read this! The silvering on my mirrors is wearing away too and I wondered what to do about it. Now I know!
Apr 21, 2010
50
Hunter 36 Vancouver
I had to do a mirror replacement on my 36. The mirror (1.5' X 2") came off with out much fuss and the single blade scraper IS the best tool to remove the adhesive. To stick the mirrors to the backboard I used acrylic foam tape...the type the glass shops use (very thin). It has good resistance to heat and weather, change temperature, very high adhesion on various materials including metals, coated surfaces, ABS... and the flexibility of acrylic foam tape provides good sealing effect, superior resistance against impact, vibration and noise. It is also good for future maintenance or unexpected breakage. Don't forget to wear gloves!
May 13, 2011
420
Hunter 40.5 Legend Jupiter
Good post
Digging through these forum posts with my survey in front of me and 100's of pictures I took of my soon to be 40.5 and this was on my list :)
