Boom vang can be useful going upwind
My sail trim manual says that boom vang tension is useful when going upwind. Apparently, enough vang tension will open the leech of the mainsail and increase twist (very useful when the wind picks up). This happens because the vang not only pulls the boom down (just like a hardened mainsheet when close-hauled) but also pushes the boom (and the middle of the mast, which is connected to it at the gooseneck) forward and to windward.This is something the mainsheet cannot do. The masthead responds to vang tension by moving backward and downward, just as if the backstay had been tensioned. It also bends off slightly to leeward.This works as long as the mid-mast (the section between the foot and the forestay attachment point) is not too stiff. Mid-mast stiffness is controlled by lower shroud tension. Decreasing tension in the lowers allows the mid-mast area to bow more, so it can move forward (and sideways) as vang tension (or backstay tension) is increased. As long as the upper shrouds and the forestay are properly tensioned, the point where they all come together near the top of the mast remains practically motionless. The fractionally-rigged “bendy” Z-Spar mast on some H23s is ideal for this type of rig trim. If you notice, the only stay that goes to the top of the mast is the backstay. The upper shrouds and the forestay are all attached at the same level, about three feet below the masthead.The vang is properly tensioned for close-hauled sailing when the boom “floats”, i.e., very little mainsheet tension is needed to pull the boom inward to the proper angle of attack. This is because most of the downward pull is already being applied by the vang. The downside is that you need a very powerful vang to produce enough downward pull (at a 60 degree angle) to overcome the mainsheet, which is pulling almost straight down. This is why some performance dinghies like the 407 have a cascade system for the vang, and explains why 12:1 vang tackles and solid vangs are popular on true race boats. If you're just cruising around, it's not a big deal, but if you're trying to utilize more of your boat's perormance potential, it's worth looking into.So much for the theory, I’m still modifying my boat so I can applying it successfully out on the water, where it counts. Right now, I’m re-rigging my vang so I can control it from the cockpit. The cunningham is already done and it does make a difference. PeterH23 "Raven"
