Hi all,
I've been lurking here for a while, but now I need some advice concerning the First 285 built in 1991 that I bought last season. I have a question concerning one of the many "little" things I've attempted to fix.
There is a small plate attached to the mast which holds the ring used to connect to the boom vang. The plate was bent outward probably due to overtensioning. I removed the plate, put it in a vise, and straightened it out. However, when I started to replace the plate it seems that there is nothing for the 2 screws to tighten into inside the mast. I guess there was a nut inside which must have dropped when I removed the plate. Does this sound right? If so, does anyone have a suggestion as to how I can re-attach the plate short of lowering the mast?
I was thinking one possibility is to use a slightly larger self tapping screw, but I would rather go a less destructive route if possible.
Thanks in advance.
Scott
Thanks in advance.
Scott
