Peggy - I currently have a SaniPottie that I really would like to replace with something more pleasant to use for both myself and guests when we go out for day or weekend trips. At the 2010 NY boat show I saw a really appealing all in one, and very affordable unit http://www.northeastsanitation.com/...duct_Code=326002521&Category_Code=Vacuum_Tank It was immediately added to my future project list, but I just checked and found out that it is now discontinued.
page 12: http://www.sealandsanitation.com/VacuFlush Product Guide.pdf
I really liked the design because I don't have much space, and this was small enough to fit my available space, and since it is very efficient per flush (0.4L water + waste), should reasonably be able to handle a long weekend of use, plus they claimed there is no reason you cannot flush a normal amount of paper waste, so no special instructions for guests needed. I also really liked the vacuum flush design since it doesn't require pumping, and with negative pressure, odors should be a non-issue. Additional feature was that if required, you could remove the tank and dump like a portapotty, but I don't expect I'll be doing that...
Are there any similar products out there that I could look at that would perform similarly? I can still get the other unit from some suppliers, but I don't know if I want to buy one that is discontinued and find out I can't get parts anymore...
The distributor suggested the VHT12 (http://www.dometic.com/enus/America...stem-Components/products/?productdataid=96456) but just the tank alone costs 25% more than the complete system with the toilet would have cost for the other unit.
