You're right, Rick..it was. I apologize
I confused you with another Rick in San Diego who has a Jabsco manual and got a little panicky! To answer your questions:"If you can just barely put enough water to cover the ring, cut the breaker on and see is the pump trying to build pressure ie you see the water "pulsing"."Any "activity" in the bowl is a sign that the pump is pulling water through the bowl around the dome. If that's happening in your bowl, it means the dome isn't sealing...the seal on the underside of the hole may just need a little cleaning, or you may be easing the pedal up instead of just letting it go...one of the most common mistakes that V/Flush owners make. They don't realize that the pedal is spring-loaded for a reason: to allow the dome to snap back into place with enough force to seat it. Over time, easing the pedal up can cause the spring to develop a "memory" that won't let the dome seat tightly any more. "Will the toilet flush on the pump alone?"No...'cuz the vacuum pump doesn't flush the toilet...the accumulated "vacuum" (suction) does. The pump only runs AFTER the flush to re-establish vacuum in the system. Here's how it works: The accumulated suction pulls bowls contents only as far as the vacuum pump...the drop in negative pressure turns the pump on to do two things simultaneously...pull all the air out of the system between the bowl and the pump to get it ready for the next flush, while also pushing the bowl contents the rest of the way to the tank, treatment device or thru-hull. When the sensor in the vacuum tank switch senses that the correct amount of negative pressure ("vacuum") has been reached, the pump shuts off. So without enough accumulated vacuum in the system, the only thing that can move waste through the system to the pump is gravity. If there's a low spot in the hose between the bowl and the the vacuum tank, waste will drain out of the bowl, but only as far as gravity will take it. If it's uphill to the vacuum tank, the bowl won't drain.If there's an air leak in the system, when the accumulated vacuum drops it cause the sensor in the vacuum tank switch to turn the pump on long enough to re-establish enough vacuum. Failing duckbills--or a bit of something stuck in 'em that prevents 'em from closing tightly (which why it's important to run plenty of water through the pump after each flush)--or a dome that isn't sealing are the most common reasons for the vacuum pump to cycle between flushes for no reason. It may start with just a brief "burp" only a couple of times a day...then get longer and more often....till finally the air leak becomes big enough to prevent the system from ever reaching enough vacuum...at which point the pump runs continuously. A failing tank switch sensor can also create the same symptoms. That's an EXPENSIVE part...so you always want to rule out air leaks before replacing it. You said, "You are not building up vacuum pressure so, you have a clog or a leak."If the tank switch has failed, it can cause the pump to run continuously even though the system has full vacuum. Nor does a continuously running pump indicate a clog. As long as there's no air leak, the pump will shut off. A clog won't cause it to cycle, either...it'll only prevent anything from getting past it. And btw, it's very rare for a vacuum pump to fail unless it's allowed to run continuously for so long that it burns out the motor...which is only likely to happen if the owner is brain dead or not aboard to hear it running. They do wear out after 15-20 years, and flushing a sharp object can put a hole in the bellows (which causes a whole different set of symptoms)...but a failed pump is almost never the cause of most problems. "Leaks are usually self critiqing because they stink."Nope...'cuz air is being pulled INTO the system through an air leak...it's not being pushed out. Permeated hoses would be the most likely source of any odor around the system. That's where I stopped reading your reply and jumped in with both feet, thinking you were the Jabsco owner. If I'd kept reading I've have seen that you did give good advice about the duckbills, especially the part about making sure they're aimed the right direction. If you don't have to remove the pump to change 'em, it's not hard to get 'em in right. But if you have to remove it, only the arrows on the pump provide a clue to which end is "in" and which end is "out"...making it all too easy to set it down backwards. I know, 'cuz I've done it. That's simple to correct, though--although taking the hoses off again and putting 'em back after turning the pump around can be a PITA...UNLESS you've already put everything back that had to be removed to get to the pump before testing the system. Lesson learned: always test the system immediately after any repair or maintenance before you put the hose clamps on and/or put anything else back.
