At one point I had a block on the bow rail so I could pull the mast and set the forestay. I still haven't got a Johnson lever yet but I simply loosen the turnbuckle. On my 26s I have no backstay adjustment.
This year, if I ever get it in the water, I going to run with two forestays. My shrouds all go to the masthead and I have a shorter mast than you all by about a foot and a half. My fractional forestay is only like 3 feet down. I will loosen the unused forestay ( and if'n it's the lower one, I'll bring it to the mast)
Doc, how is it that all your shrouds go to the masthead, yet the forestay is attached lower? this would add tremendous stress on the rig when sailing in decent wind... the variable wind loading in the jib would be continually flexing the mast quite a bit more than is normal.
if the upper shrouds go the the masthead, so should the forestay..... and you need lower shrouds to give some rigidity and strength to the mast. the side loading can be severe on an unstayed or improperly stayed mast....Or let me put it this way, the side loading
is severe and can be
catastrophic on an unstayed or improperly stayed mast
BUT... i'm curious about your thoughts of running 2 forestays.... are you going to try to fly 2 headsails at once? or which stay would you use to fly the single headsail from?.... what is the point of the second headstay? or second headsail?
keep in mind that tensioning both headstays to the proper specs will severely overload the tension on the shrouds, or the boat and its entire rigging plan in general.... but running them a bit slack should be fine for the rest of it....
I have though about trying twin headstays (side by side) so i could have the genoa hanked to one and the jib on the other one... I dont have a furler and it would be nice to just douse and hoist when i feel the need to change sails, rather than un-hanking and stowing, then hanking on the other sail.... it would be a big time saver, but i think i would need to have a way to tension one or the other forestay, and not have than both tight at the same time...
my modified stem fitting allows for a connection of 2 stays that would spread apart about 7 inches at the base, (so the stay cables wouldnt rub or foul one another) its a thought of mine but I have no plans to try it at this time, but i am curious about others who may have tried it or thought about it.
