V-birth Port Lights
K
Kevin O'Neal
Regarding 1983 27' I'm looking to replace the lenses on my V-birth Portlights. I've visited the Pompanette, LLC web site: http://www.pompanette.com/pompweb.nsf/731d6514ff5a8481852567be000745b2/d730fe8995d8eee085256c450057db03?OpenDocument but don't know which lense fits the smaller windows in the V-birth, or what part number to order. Any ideas? Am I going down the correct path? Thanks for any help! Kevin
W
Warren Renninger
Past Info
I have a 1980 H27 and think the port lights are the same for yours. I ordered mine from JSI (Sailnet) in 1998 and ordered BOM GP 907-29 Lens only 5x12 clear. Also see if GP094-09 T gasket is the correct gasket for these port lights. I ordered 16 ft and can't remember if they fit the small port light and the big ones in the main cabin or just the main cabin. JSI/Sailnet should know. One key on these is replacing the gasket and then not tightening them down. Only tighten enough to make full contact. Good luck.
Jim A.
Port light lens replacement
I recently replaced all portlight lenses on my 1980 Hunter 27. I can't find the order form to confirm part numbers, but just measure your existing lenses, and find the ones closest to the measurement on the Pompanette site. I ordered directly through them, and they were exact replacements.
