details
The v-berth was made out of plywood (1/2 inch). I ended up using 2 4x8 sheets. I used the following tools:Jig-saw circular sawhand-drill (and the appropriate bits)screw-driver.The Hunter instructions call for routing out a groove in the boards for the parts to fit together. I didn't have the right tools for this so I bought some 1/2" x 3/4" molding strips and glued them to the necessary boards to provide a slot for the boards to fit together.It took me about 2 weeks (an hour or so a day) to finish the project. I first validated the measurements that Lamar gave me. I used some card-board cut-outs to get the angles and curviture right on some of the boards. After I cut all the boards, I primed them and then put two coats of enamel acrylic latex paint. After everything dried for a couple of days, I screwed everything into place. The cost of materials was fiarly low but I did spend quite a bit of time doing the project (although, I enjoy doing stuff like that). Remember, measure twice, cut once!!!If I ever decide to take it out, all I have to do is remove the screws and the boards will lift right out.Jeff
