V-Berth Curtain
11
Catalina catalina 30 Gulfport, Fl
The curtain on my 1987 Catalina 30 that closes to give the V Berth privacy needs to be replaced. Does anyone know where to get this? Thanks...jeff
May 23, 2004
3,319
I would try to speak with Catalina directly. If you don't get any luck there try Catalina Direct.
mortyd
Dec 11, 2004
952
Catalina 30 easy living
when catalina told me the price i forgot about it and haven't thought about unti now. i think all it did was block the flow of air through the v berth on hot nights. i also think it looked cheap.
mortyd's right about pricing. When our old portlight curtains disintegrated, we shopped around and were aghast!
The Admiral took the five thousand little hooks out of the old ones and made new curtains herself out of some nice nautical material.
If you want one, make one.
Good luck.
May 23, 2004
3,319
I do agree that I rarely, and I mean rarely, use mine. When it is cooler outside I shut it to keep heat in the V-berth.
If you are concerned about privacy in the front you could get a dowel rod and make a bracket to go across that area. You could then put a curtain across that area hung by that dowel rod.
Dec 23, 2009
11
Thanks guys... I think I will ust remove it and be done with it. Jeff
