v belt for Fischer Panda 12 mini
Jun 15, 2012
715
BAVARIA C57 Greenport, NY
Anyone know replacement part number or size for v belt for Fischer Panda 12 Mini? Want to buy Gates Green stripe replacement.
Jun 15, 2012
715
artboas,
Belt is fine, want to buy Gates Green Stripe belt as I think it is a superior product. Only 315 hours on unit.
How are you coming along with post for impeller changing on Yanmar?
Jun 1, 2009
1,845
Hunter 49 toronto
artboas,
I'm down in the 1000 islands right now, and am trying to get some time to finish this.
I did a complete write-up in email format with photos, etc which I shared with Hunter & Yanmar.
I tried to easilly convert this to pdf, but didn't work.
Therefore, re-doing it as a word doc, so I can save as pdf, or just forward to folks who want to see it.
The modification works perfectly, and impeller change (excluding taking out the damned stairs) is 10 minutes at most.
I'll be back in Toronto in about 2 weeks.
If I don't get this finished while on board, I'll make sure it gets tidied up once I'm home.
Other issue is not great access to wifi here in the islands.
Thanks for your patience!!
