Some WM OK in NE
I have used West Marine’s ablative CPP antifouling paint for my boat moored in Long Island Sound with good success. It did not cost $59 a gallon, closer to $90 a gallon on sale, so I think it is different from the paint mentioned earlier.This year I will be trying West Marine’s PCA ablative with anti-slime. This is similar to Interlux’s Micron Extra except that it has less copper. You can even tell the copper difference by the weight of the two brands.Nevertheless, last time I checked Lake Erie is fresh water. My understanding is that for fresh water VC-17m is excellent antifouling paint. You should not require the copper that salt water sailors need.However, check the VC-17m can for application recommendations as I think this paint may have special preparations for this paint. I also believe this paint will wear away and not leave much paint build up as modified epoxies or other vinyl base paints.See the link below for the West Marine VC-17m. I would also go to the West Marine catalog for a more thorough description.
