My Catalina 30 has a medium service davit set that uses 1" stainless steel tubing properly and professionally made. From my split backstay I am considering taking a lead off back to both horizontal arms of my dinghy davits to give them additional support to help control the stress the arms have with the dinghy up so the motor may be left on it. Currently I remove the motor and hang it off the pushpit but that's time consuming and a pain in the rump and would prefer to just leave it attached to the dink. I have adjustable stays leading forward from the vertical davit posts to padeyes on both sides on the deck ahead of the davits and will add an additional cross beam to help make it a tighter box. The line from the backstay to the davit arms is meant to help stiffen up the box that all the points of the davits form. I don't see an extreme amount of weight being added to the back of the rig but want to know if anyone else has done this. I know I will have to tension the rig correctly when this is added.
Thanks
Thanks
