i have owned many boats in my lifetime but nothing newer than a 1990 model, or larger than what I have now.... and I have never seen a relay being used on any of them, other than a start relay (solenoid).
relays ARE used on all the tug boats/fishing boats I have worked on, but ive never seen them used on smaller pleasure craft...
my question is,.. on a boat, why would it not be acceptable to use a regular SPDT Bosch Relay to operate the heavier amp load devices, such as bilge pumps and radios?....
it takes about .01 of an amp to operate the relay, and by getting the relay closer to the device, the load carrying wire run could be at least 10 times shorter, and in turn, have less voltage loss, and a more efficient and longer lasting device
it wouldnt be practical or necessary for all electrical needs, but why dont we see these being used more on boats?... especially where they could make a BIG difference.
its possible that relays ARE being used on newer boats, but I dont know these things... all I know is what I have seen and experienced, and I have never seen relays on any of the sport boats I have ever owned.
on the Cal that I bought, the batteries and buss panel is on the port side near the aft end of the engine. the electrical panel is at the nav station on the starboard side just forward of the engine... the wire run to the panel from the batteries is (routed as it is) about 12ft....
so almost all the circuits that go elsewhere in the boat, other than near the nav station, has at least twice that amount of wiring to get to it( from the batts to the switches at nav station, then from the switches to component), and then the return to ground.... all of this wiring must carry full current demand when the devices are operating.
by using a relay in the bilge pump system, I could shorten the actual load carrying wire to 5ft, without making any changes to the switch panel, AND it would reduce the load on the float switch to a very minimum "signal" amount of current, which is about 1/100th of an amp... yet still deliver a stronger current to the device itself...
even on our simple little sailboats, I see advantages in using relays in the circuits for bilge pumps, large freshwater pumps and vhf and ssb radios.... because they can all demand a high amp load at times.
I suppose one way to help the system without the use of relays, would be to put a heavy buss panel at the nav station near the switches... with 2 or 4 gauge wire going to it... this would allow a better power draw to the switch... which may be the best way to do it since it seems to have been working reasonably acceptable as it is for the last 37 years...
