I used my new generator this weekend for the first time and have a couple of questions. First,I am using the EU2000 via the shore power cord with an adaptor from the round 30 amp to a standard 110 plug going in the face of the generator. First I am getting a reverse polarity light on my 110 panel and a ground fault on my Prosafe galvanic isolator monitor. So I tried reversing it by using an extention cord without a ground prong and reversing the plug- no change. I have called Honda tech service- in a nutshell they don't understand the boats systems. Called Promariner and they say the generator is apparently not grounded properly and said the galvanic isolators should be bypassed when off shore power, by using the sliding switch on the 110 panel from shore power to generator. I told them it was a portable not built in generator and was using the shore power cord to connect it. Then they said to disable? the isolators when using the generator but be careful as it is not grounded properly. Now how do those of you that use the EU generators connect and use them, seems like I am missing something simple here. Possibly just a ground wire off the face of the unit to ships ground?? Let me know from those of you that actually use one, not interested in possible ideas, but real life applications. Thanks a bunch- Mike
