Using Drano for Disassembled Toilet Parts Cleaning
Apr 16, 2024
4
MacGregor Venture 25 Lake Michigan
Hello,
I was looking to see if anyone has experience using Drano (or open to other suggestions) to clean a disassembled toiled? I have a Groco HF taken apart and am trying to clean the sewage residue off the inside of the pipes and other crevices that are hard to reach. I was hoping to put them in some solution that could dissolve/remove the residue just by soaking.
I have looked around and only have found suggestions on NOT using it for an installed system (general consensus seems to be that Drano shouldn't be used due to it attacking seals, and could cause dangerous fumes). But for just soaking the parts (without rubber seals, etc) where it would be thoroughly washed off before reassembly, I am wondering if anyone has any input? Appreciate anything you might have, thanks.
7,695
Alden 50 Sarasota, Florida
Sodium hydroxide is a corrosive base which can deteriorate just about anything other than some plastics. That’s kind of like using a sledgehammer to bang a nail. Hot water would probably be more effective and be safer
Likes: JoeWhite
dmax
Jul 29, 2018
1,335
Telstar 28 Buzzards Bay
Plus one on that - Drano as a last resort - if you have some mineral deposits you can't get out, use Muriatic acid (hydrochloric), 10 - 15% available in big box stores.
Jun 2, 2004
3,653
Read the label when you find it at the store the concentrations vary widely between manufacturers. I have also found it at the same big box stores in the lumber section with the cement stuff at one price and in the pool section at a different price.
If you know someone with a pool you could just borrow a cup.
I usually cut it with equal parts water in the first go around then go with a higher concentration if needed. Wear eye and hand protection, long sleeves and use outside in a VERY well ventilated area.
30% vinegar is also available and has a wider number of uses. Works great on shower doors and shower heads if you get build up. You may get more use of a gallon of the vinegar than the muriatic acid.
Apr 16, 2024
4
Hi all, thanks for the feedback! Appreciate all the info and glad to have a great community of helpful individuals!
Dec 2, 1997
9,011
- - LIttle Rock
Weekly 1-2 cup doses of distilled white vinegar will prevent mineral buildup in hoses, but it's way too labor intensive (vinegar must be replaced hourly--something few people never bother to learn, so they claim vinegar won't work) to remve a buildupA 12-15% dilution of most commercially available muriatic acids flushed all the way to the tank, followed after 45-60 minutes with plenty of clean FRESH water will dissolve buildup in hoses. A SERIOUS buildup--the kind that can reduce the diameter of 1.5" hose to <1/2"--may require more than one treatment.
--Peggie
