lift boat hoist fork lift
Difference between 25 and 26 is super critical here.25 has lead keel, and trailer had bunks front to back.26 was waterbalast, and trl bunks were in a V at the daggerboard point, and just after the drain / fill valve.I would do A LOT of research before you try to lift it out of the water. if you have the water balast, I'd try to blow the balast with air pressure 1st.given a choice, I think I'd go for straps, rather than a forklift type of lift. be really carefull.Do it wrong, and she just could crack like an egg.on the other hand, just get a good lawyer and go for it.
