Another Yanmar 3YM30 owner told me the coupling/joint between the exhaust manifold and the mixing elbow in his h36 broke in half while under way, creating some excitement... I pulled mine it to clean/inspect, and the joint broke fairly easily while trying to separate the parts. Engine is 10 y.o. with760 hrs for reference.
$400 later I now have a new mixing elbow, joint, and exhaust manifold. To make future disassembly and inspection easier or at least more probable..., should I use TefGel or pipe dope on the joint? Both sides are NPT type threads with the elbow side having LH threads, not that it matters. The mixing elbow and exhaust manifold are cast iron and the coupler joint is stainless steel.
TIA
Dan
TIA
Dan
