The Yanmar 3GMF on my H35 has been plagued by a fuel leak at the banjo joint on the discharge side of the engine mounted fuel filter (not the upstream Racor) due to the retaining bolt constantly loosening. When it gets too loose it also causes hard starting problems when air enters. Yesterday I managed to strip the threads on the casting when I was tightening it for the umpteenth time. :cussing:
A new assembly, banjo washer and bolts are now on order. Should I consider using some thread locker to prevent this cycle happening all over again?
