use of agicide in water ballast
2
hunter hunter 26 St-Zotique
I recently acquired a H26 water ballast boat, Is it advisable to put algicide or bleach in the water ballast to prevent odours and growth? will it damage anyting?
Thank you for your advice
André
May 25, 2004
958
Hunter 260 Pepin, WI
I guess it depends on how long your boat remains in the water. Mine holds the same fresh water for 4 months. I definitely put 1/2 gal of bleach in when I launch the boat.
Aug 11, 2006
1,446
Hunter H260 Traverse City
If you care about the environment, you'll just leave it alone. Anything you put in the ballast tank will end up in the water.
Oct 16, 2008
184
hunteer 23.5 st lawerence
I have a 23.5 and sleep weekends on it all summer , never had a smell issue with the tank here"fresh water "lake
May 31, 2004
90
-Hunter 23.5 Sandusky, OH
When we purchased our 23.5 in 1993, folks around Lake Erie were trying to figure out how to deal with the invasive species, Zeebra Muscles. We contacted the Ohio Sea Grant, an envirionmental group that's associated with Ohio State Univ. and several other universities and government agencies, because we, at the time, were planning on trailering Kinship between Lake Erie and several inland lakes in NE Ohio. The recommendation that we got was to add 2 - 4 oz. of househould bleach to the ballast tank to kill any zeebra muscles. They felt that, since chlorine naturally breaks down so quickly, that little, if any would make it into the lake, and there should be little to no environmental impact.
Jun 2, 2004
3,612
I Add a Gallon Every Year
Or whenever it is launched. Never smelled a whiff of bleach or any foul smell when it is pulled.
boubou
Oct 30, 2008
11
hunter H306 chazy river
no odour
It will only smell when you open it at the end of the season.
