Preventer also helps vang the main
With the main out as far as it should go, the preventer and the mainsheet are pulling down on the boom from fore and aft, helping the vang to hold it down.While running, the most likely time for the preventer. the following wind is diminished by boat speed away from it, so my experience is that if major shifts or big following waves allow the wind to get behind the main, the boat is stable enough to allow steering the wind back into the main.If a wave dips the end of the boom in the water, a preventer attached forward of the aft end of the boom can put enormous forces on the spar, even bending it. So I prefer the end of boom configuration.Our vang has snap shackles on both ends to allow easy use as a preventer.DavidLady Lillie
