Urgent rigging help needed
Mar 23, 2005
66
Hello all,
Well, our dear vega is finally about to get back in her element after
her year long refit. I had a quick question about the lower shrouds.
One is longer than the other, and I can't remember which is which. Is
the aft lower shroud (the one that attaches right below the spreader)
longer or the forward one?
The boat is going in the water tomorrow, so quick replies would be
most welcome.
Thanks already,
Cedric and Melissa
"Lyra" V-2941
Feb 4, 2006
22
to alan critchlow:
send me your mail adress and I will send you a Vega-Handbook
archikum@...
Le 18 mai 06 à 15:18, cedricbaele a écrit :
Oct 31, 2019
6
I'm about to put the mast back up on my Vega "Fleur" and have the same
problem - however I can't find anything in the handbook which makes it
clear which shroud goes where.Any help would be appreciated.
John
Jun 11, 2006
1
Hi John.
The top shroud from the top of the mast, going through the end of the
spreader, goes to the middle of the 3 U-shaped attachments. Since the
mast is vertical and the deck slopes slightly downward, backward, I
guess that the front, lower shroud is shorter than the rear lower shroud.
Good luck.
Gudleik Alvik, Vega 184, harboured in Gjøvik Norway.
Oct 31, 2019
562
Hi:
The longest shroud is the forstay. The shorter is the
backstay. Then you have two equaly long shrouds for left
and right, and four shorter ones for the lower for and aft
(I didn't use the nautical terms like starboard etc.) The
backstay goes into the V-connection.
Wilhelm, V-257
