Urethane Props Fell Off
JacK P
Jun 21, 2016
12
Hunter 28.5 Brick, NJ
Just purchased a 28.5 with a urethane prop. Transporting up Jersey coast the prop broke and fell off. The original prop is on board. Is the a method to check the quality of the original or is it better to purchase a new prop to meet the specifications of the boat.
Oct 29, 2005
2,363
If i were to do it, I'll put in a new prop and keep the old one as get you home spare.
Jun 3, 2010
177
Hunter 27-3 Erie
I think my first step would be to contact the PO and ask why they swapped out the OEM for the plastic job? Was the OEM a poor performer, damaged is some way or? Must be a reason. You could then contact Michigan Wheel via their website or call them for technical assistance in ordering a new prop. We used a plastic 4-blade prop on an outboard many years ago for a performance improvement at a cheaper cost that aluminum or SS. Like Ken suggested, I had everything on board including the OEM prop as a backup in case the plastic prop was damaged.
