I have a crack in my starboard upper shroud chainplate. Obviously I will have to replace it, but the currently available replacement plate has a 5 hole staggered bolt pattern where the chainplate is bolted to the bulkhead and the pattern on my present plate is 4 hole inline. Has anyone done this replacement before? My Catalina 30 is a 84' hull #3701. I am told by Catalina direct support I can either use the "upgraded" 5 hole pattern which will now have 9 holes in the bulkhead or send the old chainplates to them to be basically refabricated using the old plates as a pattern. If I go with the new style plate I think I would have to strenghten the bulkhead with say a piece of 3/4" teak the size of the chainplate and bolt it to the existing bulkhead then use longer bolts. Any Catalina owner that may have done this replacement would be much appreciated.
