Upgrade from st3000 to st4000
A
Alan Huffman
I have a new(to me)Catalina 30 with an ST3000. Surveyor could not get motor to operate, althoug the controls appeared to be functioning. 1) Can I get a new motor if it checks out bad 2) if I upgrade to the ST4000 will any of the existing wiring be of use?
Bill Boudreau
Part Numbers
The ST3000 system consists of the control unit, drive assemble, belt and wheel drum. The drive unit has a small dc motor that turns a planetary gear box and in turn the main drive cog. There are also several different generations of 3000 autopilot. This response is assuming that this autopilot was manufactured between 1990-present and that it is an ST3000. Q101..............ST3000 Motor Q045..............ST3000 Drive Assembly The Raymarine repair center would be happy to take a look at the drive unit for you. Please check out the website at www.raymarine.com for shipping contact information and details.
