Update O'Day 26 Head
10
Oday 26 State College, PA
Peggie, I just purchased a 1985 O'Day 26 and as the broker said, the head is not her best feature. It appears functional but if I choose to replace it with an electric head, do you recommend the Raritan SeaEra? We will use the boat in freshwater and an occasional saltwater trip. This boat has a little Yanmar diesel, standard 15 gal fresh water tank, two batteries, and will usually be charged with a solar charging system. Should I use sea water or freshwater and what do you recommend for this size boat?
Dec 2, 1997
9,011
- - LIttle Rock
IMO electric on a 26' sailboat is overkill
I doubt there's even room for one in the head compartment. If I were you, I'd go with manual Raritan PH II, or the PHC, which is the same pump but on a compact base to fit in a tighter space. Or better yet, reclaim all the storage space that's been sacrificed to the tank and plumbing by replacing the whole system with a self-contained system. A 5-6 gal portapotty designed to be permanently installed and fitted for pumpout requires no plumbing except a vent and pumpout hose...flush water is in a reservoir...and will hold more flushes than your 15 gal tank connected to any manual toilet. Check out the Thetford 875MSD and 885 MSD models here: http://www.thetford.com/marine_series.cfm The 885 MSD is even available in an electric version powered by 6 AA batteries.
Dec 6, 2006
10
Overkill are me
Peggie, What me, overkill, naaaaa. As usual, you make great points and caught me wanting to do something I should have done on some of my bigger boats in the past. I will evaluate all my options early this spring and take some measurements and maybe service the existing unit. Thank you very much.
