Ralph Johnstone
Perahps I've been away from sailing for too long with our long wet winters here and I'm just looking for something to worry about. Hopefully you can help.I will be installing a wind meter at the top of the mast on our 1999 H310 in a few weeks. I will be using a bosuns chair and with my luck, I expect to be up and down more times than a toilet seat at a mixed party.If you consider my weight at 180 lbs. and my weight pulls down on one side of the main halyard block while someone pulls down on the other side with an equal and opposite force of 180 lbs., the mast is now loaded down with an additional 360 lbs.Has anyone ever experienced or heard of this causing any problems with the mast assembly when making numerous trips up and down the mast ? Thanks for your input.
