I've done this.
I bought my '85 h31 this spring and had to have it hauled overland. I had a boat yard unstep the rig, but I disassebled the spreaders and shrouds myself to pack it for travelling. Putting it back together was no big deal (my wife and I did it in about 2 hours). Putting it back up took a little longer, and I ended up needing 4 helpers, but I did a couple of dumb things.I assume you're just pulling the rig to store for the winter. My previous boat was an old 31 footer with a wooden mast, and I pulled the rig every year for eleven years, so I have some experience at this. The Hunter rig is a little heavier, but not much harder to do. Here's some pointers:1.As stated in previous posts, hook the crane up BEFORE removing any rigging.2.If you mark the turnbuckles with tape before you loosen them, it's way easier to tune when you get it back together.3. You really only need to loosen turnbuckles on one side (port or starboard); that should give you enough play to take out the pins on the other side. Again, this makes it easier to put back together.4.Use a heavy rope for lifting. I use a 7/16" Dacron jib sheet. Don't use nylon; it stretches too much.5.Lift the BandR rig ABOVE the first set of spreaders; it's very top-heavy and won't balance very well if you lift below the spreaders. I made this mistake when re-stepping and needed 4 people to horse the butt end down onto the deck plate; if you balance it right it's a two man job. You'll have to go part way up the mast in a bos'n's chair to attach the rope above the spreaders.6.Have two people to help you; one to work the crane, and one to help control the mast while you loosen the rigging.7.Remember to unplug all the electrical connections as soon as the mast is a few inches above the deck, or you'll rip the connectors off.Like most things on boats, once you've done it once it will seem easy. Our boat yard charges about $200 to unstep a mast, and I can do it with a couple of friends in about two hours, for the cost of half a case of beer. Good luck.
