The Oday 25 was designed for the boom to be used as a gin pole . Disconnected the aft stay and slowly relasing the mainsheet gave a huge purchase and a fair amount of control when lowering the mast faorward . The rear pivot pin needs to be removed at the mast step first . When the mast in near the bow pulpit ,there will be much more weight from the mast over the front of the boat . When the forward pivot pin is removed the mast is going to want continue it's pathoff the front of the boat . This is where every able body needs to be positioned .
Now ,if you are planning to step and unstep the mast every season ,a gin pole that clamps to the front base of the mast step works considerably better. I'm nearing 60 and I can raise and lower the mast on our Oday 25 safely and with full control with the boat on the water by myself. All materials were under $50.00
