I have a Universal M18 in a Catalina 30, I have to hope every time I turn the key, sometimes it cranks, sometimes nothing. Last seasons solution to this was a spare battery on board that I would use to jump the installed engine battery.
I have 2 EGC golf cart batteries in series for the house and a 600 CCA group 24 dedicated to the engine. My initial thought was the batteries were bad, and was planning on a new set for next season.
Since hauling I've taken the batteries out of the boat, load tested them and done more research. From what I found given the condition of the batteries, they aren't that bad, the cranking battery holds 12.7V and the house 12.6V, by the load tester they are "good" I wouldn't expect to have been having the problems cranking I was. I need to maintain 9.something volts under max cranking load for the starter to turn. I'll check the voltage drop, I'll also check the wiring. My question is: is excessive voltage drop a symptom of a bad or deteriorating starter motor?
Thanks for your thoughts,
John Rolka
John Rolka
