H
Humbled
Well, I have personal experience that the 170 can tip over, and more. An unrelenting long stong gust of wind got me this weekend. I tried to quickly furl the jib, but the furling cleat would not catch. The angle was wrong. I was already heeled way over. The main was cleated but I was headed into the wind, or so I thought. Over I went. It was not very fast, 3 seconds, so there was no danger of my bumping on anything on the way over. But there I was, swimming -- embarassed, humilated. I was not planning to get into the drink until July or August. It was cold, real cold. The 170 was on its side, at least initially. I tried to get to the centerboard, but it was too high to grab, and by that time the boat turtled, and the centerboard retracted. Luckily the water was deep. There was NO way to turn it over again. Sails up or down. Ropes, pushing, pulling, and lifting had no effect, except to get me and my motorboat rescuers exhausted -- mostly me. I was in and out of the water for 45 minutes until a motor boat had tugged the boat to my deep water floating dock. I considered leaving it there, just like that, for a while. My shivering was uncontrollable in the wind. My mind was fussy. Hyperthermia, I guess. After changing into dry clothes, a hero jumped into the water with a face mask and managed to remove the sails, the boom, and the MAST. I think I have all the pieces. The boat was beached, and only then we could turn it back right. It took a great deal of effort for 3 adults standing on the beach to right the boat. The 170 canNOT be turned over when turtled, except at a beach (or if you have a crane).What have I learned? (1) Start sailing when the water gets warm, and especially when motor boats are around to help you; (2) the 170 CAN turn over, even with its wide beam; (3) it's a heavy boat.Possible improvements I may make? (1) attach a rope to the end of the mast and attach it to a side stay so that righting the boat MIGHT be possible; (2) replace the ruller furling jib line with a thinner and longer line so that furling can be done more easily -- maybe replace the cleat entirely; (3) add a line so that the centerboard will not retract until I want it to; (4) replace the clevis and cotter pins that attach the stays and all of the other removable hardware to the boat, so that they can all be removed more easily and quickly, if necessary, in an emergency and from under water.It may be a while until I'm sailing my 170 again. I have to check that all is in order. Pfew. But I think all I lost was a hat, some rope, and my confidence.
