Universal M3-20 diesel equivalence
cadams
Nov 12, 2009
18
Catalina 30 Bear Lake
I may buy a Catalina with a rebuilt Universal M3-20B diesel. I am trying to find out two things. First, what is the difference between the Universal M3-20B and the M3-20A. More importantly, which Kubota diesel is the "equivalent"?
Thanks in advance for any help you can provide.
cadams
Nov 12, 2009
18
Jack, thanks very much!
That shows the difference between the M3-20 and M3-20B. Much appreciated (and kinda glad I have the 20B with a bit more HP).
Anyone know the Kubota diesel equivalent?
cadams
Nov 12, 2009
18
Still don't see it in the link. It shows: "The Model M3-20, a 38.9 cu in, 18 hp, 3 cylinder, based on the Kubota D-640 block, was built from 1988 to 1997. Approximately 525 were sold. The Model M3-20A, a 3 cylinder engine producing 13.4 kW / 18 hp at 3,600 rpm , based on the Kubota ?? block, was introduced in 19??." and " Universal models available in 1998, the 100 year anniversary of the first Universal motor, were the 3 cylinder M3-20B (20 hp) and M25-XPB (26 hp), and the 4 cylinder M-35B (32 hp) and M-50B (42 hp), all Kubota based light diesels converted to marine specification and fitted with integral heat exchangers and Hurth transmissions."
Still no equivalent model number for the M3-20B. Do you think the M3-20B is built on the same block as the M3-20 (Kubota D-640 block). I may be missing something, but it is a bit of a mystery. Thoughts?
