Universal M25XPB Chugging in gear with no throttle
31
Hunter Passage 420 San Diego
Hello everyone,
So this past weekend I repacked the stuffing box according to MaineSail's fantastic tutorial. When I started the engine back up and put it in forward at the dock, it began to chug and shake.
Here is a video. Forgive the camera work, just listen to the sound its making when I have it put in forward.
http://www.youtube.com/watch?v=EKRcHM_rx58&feature=youtu.be
It only made the noise in forward. Not in reverse. I wanted to try it away from the dock, so we pulled out in reverse then I put it in forward. same thing.
Until I gave it some throttle. Once I gave it some throttle, it smoothed out for a bit but we still weren't really moving, then it "Clunked" and I felt the boat push forward. So clearly its a gear issue, like the Transmission isn't fully kicking into forward? And maybe its somewhere halfway between neutral and forward when there is no throttle?
I checked out the gear cables as it was put into and out of gear but I couldn't see anything to my mechanically untrained eye. Does anyone have any suggestions on how to troubleshoot or fix the problem?
It wasn't doing this before so Maybe I bumped or pulled a transmission cable while I was working on the stuffing box?
Any and all help is much appreciated. Thank you.
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
From the video it looks like your alignment might be off. The "clunking" appears to be the shaft making contact with the side of the stuffing box. Perhaps you didn't seat the rings of packing well and that's the problem.
Have you put a temp gun on it to see if the stuffing box is getting hot?
But there does appear to be a lot of vibration when you are in gear. That could be caused by the shaft hitting the stuffing box but I can't tell much from that video. What does your tranny fluid look like?
Oct 4, 2013
31
Hm. I didn't realize that could happen. MaineSail's instructions on page 3:
http://www.pbase.com/mainecruising/stuffing_box&page=3
Were somewhat unclear as far as how to get the rings into the stuffing gland and I may have done it incorrectly. Now that I've done it, I think I understand a little bit better how I would do it again.
No. I checked by touch (using a wet cloth first) However I actually did take the boat out sailing because it smoothed out when I throttled up :redface: Maybe a little dumb I'm aware. BUT... after motoring out of the harbor, sailing, and motoring back in, the Stuffing box was NOT hot at all. And it seemed to be dripping at an acceptable rate of 5 to 10 drops per minute. This is why I thought the packing job was fine.
I just changed the Tranny fluid on Saturday the day right before I repacked the stuffing box. I may have overfilled? But if I did it was only barely (it's so damn hard accessing the dipstick to continue checking and to make matters worse the ATF can be somewhat translucent).
Aug 24, 2009
444
Catalina 310 Sturgeon Bay, WI
On another note - your missing the foam element that covers the air intake unit. Keeps all kinds of crap from being sucked inside the air cleaner.
Oct 4, 2013
31
Wow. Yep. Thanks for pointing that out! I would have never known.
Apparently there are two parts, What universal calls the Air Intake "silencer" And the Air filter "Element".
So... the thing that you see in my video. That is the filter/silencer without the foam. Is there actual filtering that goes on in there? Or does the foam do most of the filtering?
In other words, what I'm asking is, should I replace the whole unit for around $70 or just buy the Foam for about $15.
Sep 29, 2008
1,944
Catalina 310 #185 Quantico
Problem fixed?
I am a bit confused. Did the noise go away after you motored for a little bit? Hard to imagine anyone screwing up a re-pack job.
On the air filter, a few of us replaced our air filters with an after market one. It was about $25-30 and was pretty snazzy. Lot better than the oem one. We had a discussion in the forum here or next time I am at the boat I can look it up. PaulJ recommended it.
Oct 4, 2013
31
Yes. here is a break down of the "knocking" sound
- Neutral Gear: no knocking
- Forward gear, no throttle: Knocking slow at first then constantly
- Forward gear, any amount of throttle: No Knocking
- Reverse Gear: No Knocking
Also note, I backed out of the dock, put it in forward and it started knocking just like before. After putting it in forward the boat was hardly moving. The propeller was spinning but felt like it wasn't spinning fast enough?
I opened the throttle slightly, the knocking went away then after a few seconds it felt like it "Clunked" into gear and the boat started moving normally.
The boat did this a couple times afterwards, where I would throttle all the way down, then throttle up and it would "Clunk" into gear after a few seconds.
Thank you, I'll look it up.
Aug 24, 2009
444
Just the foam is good enough, that is where you trap 95% of what is pulled in. Yes, If you can find the past discussion the new filter that some have switched to is pretty snazzy. The one benefit of the good old original set up is, wash it out and reuse it, over and over and over again.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
not sure but it sounds like you may need to adjust your shift cable as it may not be going fully in forward at first when you put it in foward.....this may or may not be caused by the stuffing box work...as to say it may have been border line even before and any slight movement of the cable housing could have brought it to a head....so i would check the shift cable for full motion and see if that clears up your problem...some times we over look the obvious when things go wrong and a lot of times we panic due to not fully understanding things...
regards
woody
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
Hello everyone,
What kind of prop do you have? Sounds almost like a feathering or folding prop that isn't fully deploying until you add RPM's.
Oct 4, 2013
31
not sure but it sounds like you may need to adjust your shift cable as it may not be going fully in forward at first when you put it in foward......so i would check the shift cable for full motion and see if that clears up your problem...
Yes. I believe this is the case as well. That's how it "Feels" to me anyways. I'm going to take a look at the shift cable this weekend.
Unfortunately no. Just a standard fixed 3-bladed bronze prop.
Dec 25, 2008
1,580
catalina 310 Elk River
It does not sound like prop shaft slap against the stern tube. It sounds like the tranny is not fully engaged, put it in forward and then see if you can manually move the shift arm on the tranny further, I bet you can.
Oct 4, 2013
31
So, it turns out that its not a problem with the Tranny fully engaging because of shift cables. I disassembled so many things this weekend and pulled the shifting lever as far as it will go forward by hand. Yep, still slipping.
It slips only in forward, and clunks into gear after about 10 secs of higher RPMs. Apparently, this seems to be a recurring issue with Hurth trannies. Worn thrust washers are usually the culprit and my engine has over 1900 hours on it. It used to be in a charter fleet so Im sure it has sailed in forward a number of times and the thing is probably on the point of failing.
Looks like I'm staring down the barrel of a service/rebuild/replacement. That being said, Anyone know a good mechanic in the SF bay area?
Oct 31, 2010
42
Catalina 310 RYC, Richmond CA
Chuck's Marine. I haven't used him personally but, he comes with recommendations from a couple of different people.
Dec 25, 2008
1,580
Be very careful when having someone rebuild a Hurth tranny. They are serial # specific, so the parts are not necessary interchangeable.
Clydo
May 28, 2013
363
Catalina C310 SF Bay/Delta
Checking tranny fluid
One way to check fluid level after pulling tranny dipstick is to lay it
on clean paper towel. You will be able to see clear fluid level on
towel in relation to dip stick marking.
Clyde Thorington
C310 ILEANTOO
#245
San Jose, CA
Oct 4, 2013
31
Clyde Thorington
C310 ILEANTOO
#245
San Jose, CA
Interesting that this is the last post.
If anyone was interested in what happened with this whole Tranny problem it turns out that It may have been too much ATF after all. :doh:
I had my dad with me to help me get the transmission out and in his fatherly wisdom he helped me troubleshoot some of the simple things I thought I had already ruled out.
We are now convinced I just simply put in too much tranny fluid. It turns out there is a reason they put that marking on the dipstick. Why it would cause the transmission to slip? I'm not entirely sure. My dad said something about too much pressure. I guess that's it. Lesson learned.
Looks like I will be able to move my boat from Moss Landing to Redwood City this weekend after all. Thanks everyone for the help!
