universal m25
karl m
Mar 1, 2018
3
catalina 30 mk11 lake macquarie nsw
Does anyone have any tips/difficulties replacing M25 rocker cover gasket. Thanks in advance
May 20, 2016
3,015
On cars I’d seal the cork gasket to the cover and leave the other side raw. Don’t over tighten the cover.
May 7, 2011
281
C - 30 # 3573 Lake NormanNC formerly Bflo NY
The M25 is a Kobata block. You can get a new gasket on line.. inexpensive.
One benefit of signing up on the IC30A forum is that we’ve assembled all manuals, including Kubota parts manuals, online.
May 20, 2016
3,015
In addition to the c30 site others like C34.org and CAtalina36.orghace great info on common systems, like the engine. I routinely check @Stu Jackson well organized C34 site.
Les
karl m
Mar 1, 2018
3
Thanks for replies guys, I have already got the gasket from the local Kubota dealer. Was just after any tips on doing the job, particularly any goo needed. Also are there any issues with the decompression setup. BTW the motor is a M25XP, doubt that matters much. The gasket I got is a rubber O ring type, hope its the right one.
May 20, 2016
3,015
The valve cover gasket for the M25 is a different pn than the m25XPB
They are built on different blocks.
Les
May 7, 2011
281
Neoprene is the correct gasket. On those I never use goop unless it’s a difficult location like where I need to hold it to a part while installing.
karl m
Mar 1, 2018
3
Thanks very much guys, the gasket part no was sourced as for m25xp so should be correct.
