Hello folks -
I was changing the oil on my 1985 Catalina 30's M25 and discovered I had lost a lot of oil in my bilge (cleanup in progress...). I narrowed the leak down to a small block plug next to the oil filter. It only leaks with it's running...and the leak has actually splattered significant amounts oil onto the oil filter and surrounding components. The linked photo's arrow indicates the plug that leaks, after being wiped clean.
Before I put a wrench to this, has anyone seen this before? It is a 450 hour motor that runs flawlessly. However, I may have overfilled it with oil last season (which is a different story).
Also, this will be my first post - mostly because I can always find the answer I need in older posts. So, thanks everyone - there are many silent beneficiaries of your past discussions.
Regards,
Baz
Regards,
Baz
